Block SSID broadcasting from Apple Device
  • 1.  Block SSID broadcasting from Apple Device
    Posted Oct 22, 2014 01:21 PM
    Current Setup:
    3400 controller running 6.4.1.0
    RF Protect licensing
    38 AP's
    2 Air Monitors
    Configured a WIP policy to block particular SSID's coming from numerous Apple devices(mobile hotspot).  Wireless containment is enabled and setup as deauth only
    Is the default behavior for all clients to not be able to connect to the defined SSID at all? or connect/disconnect continuously?  the air monitor(s) are in great range of the suspected device broadcasting the SSID I want to block.
    #3400
  • 2.  RE: Block SSID broadcasting from Apple Device
    Posted Oct 22, 2014 01:24 PM
    Yes, clients should not be able to connect. Keep in mind that if they're not broadcasting your corporate SSIDs on their personal devices, deauthing clients can be interpreted as illegal (US).
  • 3.  RE: Block SSID broadcasting from Apple Device
    Posted Oct 22, 2014 01:54 PM
    ok.  how can I remove an ap group from the default WIP policy?  its greyed out.
