Blocked service how to enable
  • 1.  Blocked service how to enable
    Posted Dec 21, 2016 12:36 PM
    I have problems with the samsung remote app on my iphone. It does not find my television.
    If i do a show airgroup blocked-query i see the following service being blocked:
    urn:samsung.com:device:RemoteControlReceiver:1
    how can i add this. If i add it it says invallid contex.
    Thanks for a reply
  • 2.  RE: Blocked service how to enable
    Posted Dec 21, 2016 01:05 PM
    Under the SSID and advanced, change Broadcast Filtering to disabled.
  • 3.  RE: Blocked service how to enable
    Posted Dec 21, 2016 01:10 PM
    I had that already disabled.
    I found another thing that worked for me.
    IAP-335-Test# config t
    We now support CLI commit model, please type "commit apply" for configuration to take effect.
    IAP-335-Test (config) # airgroup
    IAP-335-Test (airgroup) # disable
    IAP-335-Test (airgroup) # exit
    IAP-335-Test (config) # exit
    IAP-335-Test# commit apply
    committing configuration...
    configuration committed.
