Wired Intelligent Edge
Blocking between LAN users
  • 1.  Blocking between LAN users
    Posted Dec 29, 2017 12:58 PM
    Dear Concern and Team members,
    I need your help in my problem. Problem is that I want to restrict my one user having ip of 10.0.0.1/8 that can't be ping my another user having Ip of 10.0.0.3/8 . Which application should I use in HPE VAN 2.7.10 that can perform my such task easily.
    I need your help anyone can do for me.
    Regards
    Abdul Samad
  • 2.  RE: Blocking between LAN users
    Posted Dec 30, 2017 03:38 AM
    Hi Abdul,
    There is an SDN app that you can use that does that. It's free and you can download it from here:  http://community.arubanetworks.com/t5/SDN-SecureSuite/ct-p/SDNSecureSuite
    The app also provides captive portal functionality. It's written in PHP. The package also contains pre-installed OVA's.
    Hope this helps.
    Kind regards,
    Dik
  • 3.  RE: Blocking between LAN users
    Posted Jan 01, 2018 04:46 PM
    Hello ,
    Can you please help me in one more issue, I installed the OVA of securesuit but I can't be able to access its GUI as like my Controller by
    https:x.x.x.x:8443/sdn/ui
    how can I access its Gui to manage filtering .Please help me out I am very thankful to you.
    Regards
    Abdul Samad
  • 4.  RE: Blocking between LAN users
    Posted Jan 02, 2018 02:13 AM
    Hi Abdul,
    The OVA has a standard IP address that you will probably have to change. It's an Ubuntu host, so you have to edit the /etc/network/interfaces file and change the IP address settings. You can find the login credentials in the readme file (root/HPERocks). The default IP address is 10.1.254.250. It is also possible that the ethernet adapter name has changed after importing the OVA. In that case you have to change the adapter name in the interfaces file as well. You can find the adapter name by issuing    ifconfig -a.
    You can consult the configuration guide in the doc folder for guidance on how to configure filtering. Please note that the application works with Comware, Provision and OVS switches.
    Once you can reach the host, you can point your browser to the IP address (either http or https) and you can login with the admin/admin user credentials.
    Hope this helps.
    Kind regards,
    Dik
