We are looking at blocking bootp using a service acl then assigning to the authenicated and guest user roles. When creating the policy under Security/Access Control/polices I used session as the policy type I see svc-dhcp udp67-68 and svc-bootp udp 67-69. I choose svc-bootp in order to block bootp. Is this correct/recommended way to block bootp and how does the controller differentiate DHCP from bootp? Does this affect DHCP in any way?
I don't know what the difference is, but the logon-control ACL uses:
user any udp 68 deny
Which works in most situations to prevent clients from answering to DHCP requests. It might work for bootp. You should try it.
