blocking whatsapp
  • 1.  blocking whatsapp
    Posted Mar 01, 2015 04:33 PM
    we have clearpass and aruba controller,
    we are trying to block whatsapp application ,
    the issue is, its blocked from android devices, but iphone users still be able to access to whatsapp,
    do i need to cnfigure specific configuration for iphones?
    thanks
  • 2.  RE: blocking whatsapp
    Posted Mar 01, 2015 04:43 PM
    How are you trying to block it?
    Do you have 7 series controllers?
    Tim
  • 3.  RE: blocking whatsapp
    Posted Mar 01, 2015 04:50 PM
    yes, 7200 series controller,
  • 4.  RE: blocking whatsapp
    Posted Mar 01, 2015 05:00 PM
    via controller acl
  • 5.  RE: blocking whatsapp
    Posted Mar 01, 2015 05:35 PM
    What type of controllers do you have?
  • 6.  RE: blocking whatsapp
    Posted Mar 02, 2015 02:01 AM
    Create a netdestinetion for whatsapp.
    go to access list and create one acl to block all the traffic.
    any alias <your whtapp alias> deny
    then make the role on top.
    FYI... screenshots are added.
  • 7.  RE: blocking whatsapp
    Posted Mar 02, 2015 01:59 PM
    i created another acl also that checking for application for whatsapp,
    its working good with android device ,its blocking whatsapp from android device, but its doesnt work with iphone 6 and 6 plus :S
  • 8.  RE: blocking whatsapp
    Posted Aug 19, 2020 01:08 AM
    Acho que o whatsapp gb ou o yowhatsapp. podem te ajudar
    vou deixar alguns sites de referência para consulta:
    https://appsteregg.com/gbwhatsapp/
    http://apkpiratage.com/
    https://triapk.com/
    https://androidigitalmidia.com.br/
  • 9.  RE: blocking whatsapp
    Posted Sep 19, 2020 05:08 AM
    Why do you need to block Whatsapp? Try to replace it with another Whatsapp version like Whatsapp gb, Yowhatsapp, ...
