BOC - VRRP
  • 1.  BOC - VRRP
    Posted Oct 27, 2017 11:41 AM
    Are Branch Office Controllers capable of Local VRRP Redundnacy. I do not see any options for it in the Smart Config menu on the Master.
    For a medium sized office that is using a "Branch in a Box" solution where is terminates diverse WAN connections and acts as Default Gateway and firewall, it would be good to have redundancy.
    Thanks!
  • 2.  RE: BOC - VRRP
    Posted Nov 04, 2017 02:10 PM
    What version of ArubaOS are you using?
  • 3.  RE: BOC - VRRP
    Posted Nov 05, 2017 10:24 AM
    Currently, they are running the latest version of 6.5 on both the Master and the BOC controllers.  That however can change if need be. I have not tested 8.2 yet.
