BOM for IAP 275
  • 1.  BOM for IAP 275
    Posted Feb 18, 2015 01:43 AM
    Can anyone help with BOM for the below mentioned solution.
    “I am proposing wireless solution with 18 X IAP 275 . Need to know the BOM for IAP 275 with the accessories like external Antenna, power supply external if needed (otherwise POE switch will power the IAP) and compatible wall mounting rack kit (AP-270-MNT-V1 or AP-270-MNT-V2).
  • 2.  RE: BOM for IAP 275
    Posted Feb 18, 2015 06:23 AM
    Hi Friend,
    For this, please contact any Aruba partner or any Aruba SE of your region/Country.
  • 3.  RE: BOM for IAP 275
    Posted Feb 20, 2015 07:37 AM
    If you are a partner, or just want to know how a kitlist may look like... For many products, on the Aruba website there is an 'Ordering Guide' that sums up what products and accessories are required and compatilble.
    For the AP-275, this Ordering Guide is on the following page: http://www.arubanetworks.com/products/networking/access-points/270-series/
  • 4.  RE: BOM for IAP 275
    Posted Feb 20, 2015 09:24 PM
    • the IAP 275 contain integrated Antenna so no need to external Antenna.
    • IAP 275 support PoE 802.3at   alimentation (PowerDsine 9001) power and AC power (consult the ordring guide)
    • the only diffrence between those two  mounting kit  (AP-270-MNT-V1 & AP-270-MNT-V2 ) is the longer
    the rest of the accessory comes with the IAP (usb console cable , RJ45 waterproof).
