Wired Intelligent Edge
boot.ini corrupted Aruba 2530 Non-POE
  • 1.  boot.ini corrupted Aruba 2530 Non-POE
    Posted Mar 22, 2022 01:35 PM
    Hello, fist post
    I need to know if it's possible to re-upload a boot.ini file and if it's possible to obtain one. I was attempting to erase the config file and during the process the boot.ini file got corrupted. I tried to download a new image to the switch and it shows it to be successful, but upon reboot I get the message the boot.ini file is corrupted. Also I noticed that the image the switch shows is for a 2530-48G POE+ (J9772A) although the switch I have is a (J9776A) 2530-24G non POE switch. Below is what I get when downloading the new image
    You have invoked the console download utility.
    Do you wish to continue? (Y/N)>
    Starting xmodem transfer. Press Ctrl+C to cancel.
    Transferring YA_15_18_0013.swi...
    100% 12180 KB 3 KB/sec 00:57:31 0 Errors
    Download was successful.
    -- Download for this Product, proceeding --
    ERROR; unable to open image '/cfa0/boot.ini'
    Ready for code execution.
    ERROR: Download was unsuccessful.
    Also when performing a boot command I get:
    =>boot
    Warm booting system . . .
    ROM information:
    Build directory: /ws/swbuildm/rel_lakesrom_qaoff/rom/build/lakesrom(swbuildm_rel_lakesrom_qaoff_rel_lakesrom)
    Build date: Aug 20 2017
    Build time: 22:15:54
    Build version: YA.15.20
    Build number: 10016
    Error, /cfa0/boot.ini corrupted; please reboot to console and repair.
    Could not open Image file
    Bad code in FLASH
    Flash memory needs reprogramming or chassis could be faulty.
    Use a PC as the console and perform the update procedure
    by serial Xmodem download of the current Switch Image.
    If unsuccessful w/ downloading, then try replacing chassis.
    HP 2530-48G-PoE+ Switch - J9772(A)
    ROM Build Directory: /ws/swbuildm/rel_lakesrom_qaoff/rom/build/lakesrom(swbuildm_rel_lakesrom_qaoff_rel_lakesrom)
    ROM Version: YA.15.20
    ROM Build Date: 22:15:54 Aug 20 2017
    ROM Build Number: 10016
    I could not locate the YA.15.20 image so I got the closet's one I could find. Any help would be appreciated. I have not contacted support yet for this issue.
    dgillam
    Damien Gillam
  • 2.  RE: boot.ini corrupted Aruba 2530 Non-POE
    Posted Mar 22, 2022 03:29 PM
    You can try to delete the corrupted boot.ini and boot the switch.
    =>rm cfa0/boot.ini
    =>boot
    The switch will create automatically a new boot.ini file when it is booted.
    If it doesn't help then it is better to contact the support.
    Emil Gogushev
