Comware
  • 1.  BootROM Missing HPE 1950 (JH295A)
    Posted Jun 03, 2024 01:55 PM
    I'm having exactly the same issue as below where I can't access the bootrom and have tried updating with the IPE files available for download but none work.
    Airheads Community
    Airheads Community remove preview
    Airheads Community
    I need some help here. After a failed firmware upgrade of my perfectly working switch to the latest version 1950_12XGT-CMW710-R5106P06.ipe through the gui none
    View this on Airheads Community >
    Is it something to do with the BootROM not being included with the IPE files and if so, how can I get hold of the files to load? I think they need to be a bin or btw file.
    Any help would be much appreciated!
  • 2.  RE: BootROM Missing HPE 1950 (JH295A)
    Posted Jun 03, 2024 02:49 PM
    That do not help.?? Lot of people same problem.
  • 3.  RE: BootROM Missing HPE 1950 (JH295A)
    Posted Jun 10, 2024 05:52 AM
    No...that do not help at all
  • 4.  RE: BootROM Missing HPE 1950 (JH295A)
    Posted Jul 02, 2024 05:52 PM
    I have a similar problem, IPE upgrade which failed and now the .BIN files are missing.
    No idea how to get the BIN files from an IPE or find any BIN files to restore the switch
  • 5.  RE: BootROM Missing HPE 1950 (JH295A)
    Posted Jul 06, 2024 05:33 AM
    There is no way to do it BearHead. HPE won't give you the files as they don't have them. They put them on a flash drive but someone lost it. Your perfectly good switch is now a paperweight. But just think, now you won't need to worry about all that paper blowing around in the office.
