bootstrapping vs rebooting
This thread has been viewed 57 times
  • 1.  bootstrapping vs rebooting
    Posted Mar 07, 2013 10:27 AM
    What is the most assured way to tell the difference between an AP that is bootstrapping vs an AP that is rebooting?
    TIA,
    --Raf
  • 2.  RE: bootstrapping vs rebooting
    Posted Mar 07, 2013 11:29 AM
    "Show ap debug counters" will tell you.
    "show log system all" will also tell you who is bootstrapping or rebooting.
  • 3.  RE: bootstrapping vs rebooting
    Posted Mar 07, 2013 11:31 AM
    show ap debug system-status ap-name <ap-name>
  • 4.  RE: bootstrapping vs rebooting
    Posted Apr 19, 2013 08:07 PM
    What is the difference between these two from a conceptual point of view?
    Is it:
    Rebooting: happens for external reason
    Bootstrapping: happens when told to manually?
    I'm just confused because rebooting is technically short for "reboostrapping" considering that's where "boot" came from.
  • 5.  RE: bootstrapping vs rebooting
    Posted Apr 19, 2013 10:16 PM
    Is it:
    An access point, when it has contacted a controller will send heartbeats, typically one per second.  Each access point has a bootstrap threshold where if it misses 8 heartbeats it will rebootstrap.
    During a Rebootstrap:
    - The AP turns of its radios except those with bridge mode SSIDs
    - It tries to establish communication with the current LMS using PAPI
    - If unable to contact the current LMS (lms-ip) and there is a backup LMS, it will try to establish communication with the bkup-lms-ip as configured in the AP system-profile
    If the AP is unable to contact an LMS, it will then initiate a full reboot
  • 6.  RE: bootstrapping vs rebooting
    Posted Dec 25, 2016 06:03 PM
    So what is the fix here? I have been seeing this with one of the APs
  • 7.  RE: bootstrapping vs rebooting
    Posted Dec 26, 2016 04:52 AM
    Please provide more information about your situation, or start a new thread.  It is not possible to tell if you even have a problem that needs to be fixed.
  • 8.  RE: bootstrapping vs rebooting
    Posted Dec 26, 2016 06:29 PM
    Here is the log. We monitor all APs thru Airwave and its been alerting for this one AP. As you see, AP itself is reachable. Let me know if you need more details.
    Dec 25 18:36:52 :311004: <WARN> |AP US-CA01-02-05-AP0225-ABA03@172.22.223.195 sapd| Missed 8 heartbeats; rebootstrapping
    Dec 25 20:26:55 :311004: <WARN> |AP US-CA01-02-05-AP0225-ABA03@172.22.223.195 sapd| Missed 8 heartbeats; rebootstrapping
    Dec 25 21:53:58 :311004: <WARN> |AP US-CA01-02-05-AP0225-ABA03@172.22.223.195 sapd| Missed 8 heartbeats; rebootstrapping
    Dec 26 13:57:04 :311004: <WARN> |AP US-RAP205H-04@172.22.13.24 sapd| Missed 30 heartbeats; rebootstrapping
    (US-CA01-CON7220-LOCAL) #ping 172.22.223.195
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 172.22.223.195, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.653/0.6844/0.744 ms
  • 9.  RE: bootstrapping vs rebooting
    Posted Dec 27, 2016 04:35 AM
    You should type "show ap debug counters" to see how widespread the problem is. If the problem is with all aps, I would check to make sure that the uplink to the controller is big enough. The unwritten rule is that you need 1 gigabit connect room for every 100 APs that connects to to a controller. If it is happening to only one access point, I would check to make sure that the AP negotiated the proper speed and duplex on its switch port and that there is no congestion upstream of that AP.
  • 10.  RE: bootstrapping vs rebooting
    Posted Dec 27, 2016 05:16 PM
    What am I looking for in the debug counters to identify if there is an
    issue? Controller has multiples gig uplinks and there are less than 100 APs
    on this controller, so congestion is not an issue.
    thanks
  • 11.  RE: bootstrapping vs rebooting
    Posted Dec 27, 2016 09:02 PM
    You would be looking at whether it is happening globally or to a single AP. It is only a concern if it is happening all the time. Bootstrapping will occur if there is a momentary interruption in communication between the AP and controller. If it happens infrequently, it can be ignored if the loss in connectivity can be explained in your infrastructure. I would open a TAC case if you want it analyzed, because the variables are too numerous to run through just by guessing here.
  • 12.  RE: bootstrapping vs rebooting
    Posted Dec 27, 2016 09:12 PM
    Nevermind, found the cause; it was a duplicate IP.
