I have a few dozen 7005 controllers with about 150 AP105/205s. My boss says the security department of our offices wants to limit the access clients to our APs, which can reach outside of many buildings.
He wants there to be a hard "x-feet", let's say 10-20 feet, where a client can't connect to the APs. Most sites have 2 APs, while some have 12 or more.
I've told them we could use an Ekahau sidekick to scan and set each AP for x-dBm from the APs, so that the edge of the usable zone is at the inside walls. But that's a lot of work, and would require different settings for each AP. We could also start at a very low power level, and make have people tell me when they can't connect, so add some power here and there. Plus, someone with a 24+dB antenna could seem "inside" as the signal is "louder".
Isn't there a way to set a variable on the APs to say that receiving association frames from clients that are further than x nano-seconds away? I'm not adverse to adding a monitor-only AP, though in some sites with multiple APs they're spread out in several building.
I opened a ticket with TAC and short of tuning off client match, reducing power, etc. there's no way to do this.
Any thoughts would be helpful!
Ambidexter
