Both IAPs 225 & 215 suddenly disappeared form VC
  • 1.  Both IAPs 225 & 215 suddenly disappeared form VC
    Posted Dec 27, 2014 06:03 AM
    Hi guys, I'm very new with ArubaOS & InstantAP networks.
    Frankly speaking, today was the first day of my experience with that.
    What I've done: two 225's (one of them set as preferred Master) and six 215's were connected to one L2 segment. All ports are tagged by VLAN 3050 for Wifi-Guest access and untagged by VLAN 3077 as for WiFi-Enterprise access. Sure, with RADIUS server in the same network (192.168.32.0/22)
    And yestreday all APs were shown in Instant WebGUI. And authorize  client's requests.
    But problem number one - all of cliens (from 8 to 17 at peak) shown as a clients of only one, Master, IAP (225). I thought it wasn't a relly big trouble.
    But today only a Master IAP 225 shows both SSID in air, and none of other IAPs.
    Plus, two of them aren't shows in Instant WebGUI rather than yesterday. One is 225 and one is 215.
    ArubaOS: 6.4.2.0-4.1.1.1_46936
    None of certificates were imported.
    Single MacOS client is running on Master IAP without any troubles in authorisation or whatsoever.
    Please take a look, guys! What is wrong below?
    #AP225
    Attachment(s)
    txt
    Vasik_conf.txt   3 KB 1 version
  • 2.  RE: Both IAPs 225 & 215 suddenly disappeared form VC
    Posted Dec 27, 2014 08:13 AM
    o_O there are two Masters in the same segment of LAN.
    Now all IAPs are visible! But only 225's are using for clients connection, non of 215's made so...
    Is this a big problem or it should be different?
  • 3.  RE: Both IAPs 225 & 215 suddenly disappeared form VC
    Posted Dec 27, 2014 11:54 AM
    Gotcha!
    There is an issue with allowed in 215 channel in RU code list:
    Allowed Channels for AP Type 215 Country Code RU
    PHY Type Allowed Channels
    802.11g (indoor) None
    802.11a (indoor) None
    802.11g (outdoor) None
    802.11a (outdoor) None
    802.11g 40MHz (indoor) None
    802.11a 40MHz (indoor) None
    802.11g 40MHz (outdoor) None
    802.11a 40MHz (outdoor) None
    802.11a 80MHz (indoor) None
    802.11a 80MHz (outdoor) None
    802.11a (DFS) None
    But not only with RU, e.g. AE still "None" for every channel...
    Trying to investigate certified lists...
  • 4.  RE: Both IAPs 225 & 215 suddenly disappeared form VC
    Posted Dec 27, 2014 12:32 PM
    All done by changing country to CN!
    Full of joy, Happy NY 'n Merry XMAS!
