last person joined: 3 hours ago
Branch Controller not able to re-connect after a uplink disconnect
  • 1.  Branch Controller not able to re-connect after a uplink disconnect
    Posted Apr 29, 2016 09:34 AM
    Hi
    I'm working on the ZTP solution for small branch offices using a 7010 as Brach and 7210 as Master controller but during the WAN failover scenarios I noticed that once the VPN tunnel is broken due to a disconnect of the uplink connection or just with a simple clearing the security association, the controller is no longer able to re-establish the VPN tunnel with the master. The only work-around to this behavior is a reload. I use for the test the version 6.4.3.6
    Is anyone aware of any particular issue/bug preventing the branch controller to VPNing again? Or does the Branch controller need to talk again with Activate to retrieve the VPN gateway?
  • 2.  RE: Branch Controller not able to re-connect after a uplink disconnect
    Posted Apr 29, 2016 10:41 AM
    What are you using as your secondary uplink ?
    Do you have enabled WAN health check ?
  • 3.  RE: Branch Controller not able to re-connect after a uplink disconnect
    Posted Apr 29, 2016 10:49 AM
    Hi Victor
    I have a 4G wired  connection which I tested as primary and works great. WAN health check is actived
    Antonio
  • 4.  RE: Branch Controller not able to re-connect after a uplink disconnect
    Posted May 08, 2016 07:05 AM
    I've isolated the issues. Basically my master controller uses a public IP which belongs to a super subnet which I've configured on the static routes to make sure branch controllers send corporate traffic over the ipsec tunnel so when I lose the VPN tunnel at the remote site, the branch control tries to send the traffic to my master over the IPSec tunnel to recover the VPN . Adding a static route which points to the active uplink recovers the connectivity but this is not a solution. How can I push from the master a static route pointing to both of the uplinks ?
  • 5.  RE: Branch Controller not able to re-connect after a uplink disconnect
    Posted May 09, 2016 11:23 AM
    Problem fixed. I removed from the static route list the corporate network which contains of the the prefixes used for my Master controller and instead I've added a PBR from the user to the role applied to the BoC poitning to the ipsec tunnels and works.
    Antonio
  • 6.  RE: Branch Controller not able to re-connect after a uplink disconnect
    Posted Feb 23, 2018 03:52 AM
    Hi aboj, please I need some directions from you. I'll be setting up a branch site with a 7030 controller. Can you give me some guidelines on how to do this. Thank you.
