SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Branch Gateway - Colourless ports without switch
  • 1.  Branch Gateway - Colourless ports without switch
    Posted Feb 07, 2022 05:38 PM
    Hi Airheads, I'm wondering if it is possible to support the below scenario with a small BGW only deployment (i.e. a 7010 with no switch).
    I'd like to implement 'colorless ports' (wired authentication) - 802.1X with MAC fallback (using CPPM for DHCP profiling) into user roles with different VLAN IDs.
    For example:
    VLAN 10 = Profiling / Quarantine VLAN - ACL to allow DHCP only for profiling
    VLAN 20 = Corporate Wired (allowall ACL)
    VLAN 30 = Printers (allowall ACL)
    As far as I can tell, I can only configure a wired aaa profile on VLAN assigned to an untrusted port, but this does not seem to work.
    I've also tried adding authentication methods to the default wired aaa profile, but this also doesn't seem to work.
    Chris Denham
  • 2.  RE: Branch Gateway - Colourless ports without switch
    Posted Feb 07, 2022 06:14 PM
    yes you should be able to this.
    check the Aruba SD-Branch Fundamentals Guide
    on page 66 it describes what you want to do.
    https://help.central.arubanetworks.com/2.5.4/documentation/online_help/content/nms/intro-pages/related-info.htm
  • 3.  RE: Branch Gateway - Colourless ports without switch
    Posted Feb 07, 2022 08:05 PM
    Thanks Ariya,
    I have attempted the below configuration according to the documentation in  Central, but I cannot see the device in the device table.
    There is a DHCP scope configured for VLAN 10:
    interface gigabitethernet 0/0/0
      description DYNAMIC
      switchport access vlan 10
      spanning-tree portfast
      no spanning-tree point-to-point
      poe
      type lan
    vlan 10
      wired aaa-profile colourless_port
    aaa profile "colourless_port"
      initial-role "Profiling"
      authentication-mac "colourless-port"
      mac-default-role "denyall"
      mac-server-group "cppm_radius"
      authentication-dot1x "colourless-port"
      dot1x-default-role "denyall"
      dot1x-server-group "cppm_radius"
      l2-auth-fail-through
      radius-accounting "cppm_radius"
      radius-interim-accounting
      rfc-3576-server "x.x.x.x"
    user-role Profiling
      access-list session profiling_acl
      vlan 10
    user-role Domain_Computer
      access-list session allowall
      vlan 20
    user-role Printer
      vlan 30
    ip access-list session profiling_acl
      any any svc-dhcp permit
    Chris Denham
  • 4.  RE: Branch Gateway - Colourless ports without switch
    Posted Feb 07, 2022 11:09 PM
    for the device to end up in the user table that VLAN or interface should be untrusted or a combination of the two
    you can assign it as shown below
  • 5.  RE: Branch Gateway - Colourless ports without switch
    Posted Feb 08, 2022 06:53 PM
    Yes, both the physical interface and VLAN assigned in access mode are configured as un-trusted:
    GE 0/0/0 is up, line protocol is up
    This port is NOT TRUSTED
    The L3 Port type is LAN
    VLAN  Description  Ports     AAA Profile       Option-82
    10   VLAN010     GE0/0/0   colourless-port   Disabled
    Chris Denham
  • 6.  RE: Branch Gateway - Colourless ports without switch
    Posted Feb 08, 2022 07:23 PM
    please contact Technical Assistance Centre, they'll sort it out.
