Branch offices Acess points showing down on 3200 controller after power outage
  • 1.  Branch offices Acess points showing down on 3200 controller after power outage
    Posted Feb 23, 2014 07:31 PM
    We have power outage in Data Center and 3200 controller was unavailable for 6 hours. After power outage all branch access points were showing down status.
    I have to manually reboot APs inorder to reconnect with controller.
    Ideally access points should contact controller when its  is available. Any thoughts what could be issue ?
    Irfan
    #3200
  • 2.  RE: Branch offices Acess points showing down on 3200 controller after power outage
    Posted Feb 23, 2014 07:35 PM
    Can you run a show log system 100 ?
    Are the APs getting an IP address ?
    Were you able to console into the AP?
    From the switch can you tell if the APs is getting Power ?
  • 3.  RE: Branch offices Acess points showing down on 3200 controller after power outage
    Posted Feb 23, 2014 08:14 PM
    Can you run a show log system 100 ? yes
    Are the APs getting an IP address ? Yes
    Were you able to console into the AP? really hard as they are mounted on celling.
    From the switch can you tell if the APs is getting Power ? yes
  • 4.  RE: Branch offices Acess points showing down on 3200 controller after power outage
    Posted Feb 23, 2014 09:13 PM
    Please provide the show log system all | include ap Mac
    And also run the show log error log all | include ap Mac
    Try to ping the AP from the controller .
    How are your APs discovering the controller ? DNS , dhcp 43 , adp
    Is it just one controller ?
    Make sure the cpsec is not turned on if you are not using it
