Branch solution with few access points
  • 1.  Branch solution with few access points
    Posted Apr 23, 2018 08:31 AM
    I've a requirement to do WLAN solution with small branches and each branch with 2 or 3 APs. They also need a centralized policy. I'm planing to use CAP(s) behind a RAP, but found this topic, https://community.arubanetworks.com/t5/Wireless-Access/RAPs-and-CAPs-Provisioning-for-Branch-Office/m-p/307714. So that I can't use that choice. Another choice if looking IAP VC with VPN, the policy is separated.  Any ideas or better way, please share us.
    Thanks.
  • 2.  RE: Branch solution with few access points
    Posted Apr 23, 2018 11:08 AM
    If you are using Airwave, you can configure IAPs and centralize your policies.
  • 3.  RE: Branch solution with few access points
    Posted Apr 24, 2018 10:15 AM
    Thanks.
    At HQ with Aruba 7005, if customer is planning to use  2 or 3 broadband aDSL links that are linked to perform load sharing, can IAP VC (with VPN) at remote site establish 2 or 3 public IP addresses from HQ? if yes, please advise.
  • 4.  RE: Branch solution with few access points
    Posted Apr 24, 2018 11:01 AM
    Yes, because the controller uses the mac address of the IAP device to authorize VPN connections, not ip addresses:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/IAP_VPN/VPN_Config.htm#VPN
  • 5.  RE: Branch solution with few access points
    Posted Apr 24, 2018 10:02 PM
    Thank for your promptly updating.
    I've found at the IAP VC side, the VPN menu allows to add 2 public IP addresses(one is primary, the other is backup; see picture below). It seems like the IAP VC can choose the 1st one and select the 2nd if the 1st link fails.
    Note: I also attached my customer requirement diagram.
