Broadcast-Filter ARP checkbox is missing
  • 1.  Broadcast-Filter ARP checkbox is missing
    Posted Apr 03, 2014 03:54 AM
    My customer is using 7000 series controller with 6.3.1.3 code. I wanted to Drop broadcast/multicast in vap, when i clicked apply it asked me to enalbe Broadcast-Filter ARP, otherwise arp requests will be dropped. So I went to Configuration>Stateful Firewall>Global Settings.... i see the "broadcast-filter arp" option but the checkbox is missing, has anyone seen this before? all other checkbox in the same page are there. see attached.
    Thank you.
  • 2.  RE: Broadcast-Filter ARP checkbox is missing
    Posted Apr 03, 2014 04:20 AM
    no need to worry about making that in firewall global settings you can just go ahead and enable drop multicast/broadcast on the vap
  • 3.  RE: Broadcast-Filter ARP checkbox is missing
    Posted Mar 13, 2015 10:28 AM
    If this warning doesnt matter, then i guess they should delete that warning so it does not appear anymore!
    Cheers
    Carlos
