Wired Intelligent Edge
broadcast storm
  • 1.  broadcast storm
    Posted Jun 10, 2019 09:55 AM
    can anyone give me a template for limiting the broadcast storm. Thanks in advance
  • 2.  RE: broadcast storm
    Posted Jun 10, 2019 12:53 PM
    Greetings!
    There are two different methods that can be used to limit broadcast traffic on an Aruba switch.
    The first is to directly set a broadcast limit on one or more interfaces, using the following command as an example:
    switch(config)# interface 1-24 broadcast-limit 10
    This command sets a broadcast limit of 10% of link speed on ports 1 through 24. This broadcast limit can be configured to a value between 0 and 99 percent of the current link speed for each port.
    The second method is to use Control Plane Policing (CoPP), which can be configured at a global level to drop packets of a specific type or protocol when they exceed a specified rate. Use this command as an example:
    switch(config)# copp traffic-class broadcast limit 128
    This command enables CoPP for broadcast traffic, and sets a limit of 128 packets per second. Any broadcast traffic in excess of this configured rate limit will be dropped. For broadcast traffic, CoPP can be configured with a rate limit between 8 and 512 packets per second.
    CoPP is supported on the 2930F, 2930M, 3810M, and 5400R series switches.
  • 3.  RE: broadcast storm
    Posted Jun 10, 2019 02:06 PM
    Great, thanks for the detailed explanation..
