Hi all,
I want to limit the broadcast traffic on uplinks to 300pps.
Is there a CLI command for it? I only see the CLI commands for working with percentages.
Kind regards,
You can configure percentage or kbp/s. so not in pps, but i think percentage is a always feasible solution.
example:
# interface 1/1
# rate-limit bcast in kbps 100
# rate-limit bcast in percentage 5
Is 5 percent not very low? I'm using 25 percent?
