Hello everyone,
I was in the web management part of the HP 5406zl Switch and I was working on some security for the switch by creating user names and passwords. I had SSL turned on so I could only connect through HTTPS. After I made a change which I cannot remember what I did, I can no longer connect to the switch through the web managment interface. The only thing I can do as of now is SSH in. I'm not sure what to do at the moment and under the CLI I couldn't find anything that popped out as helpful.
Any help would be appreciated.
Thanks!
no web-managementweb-management ssl
I think this might be the problem, but ive typed the commands
no web-management ssl
and web-management plaintext
But it doesn't actually switch. I just need to get to the web interface.
