This morning I ran into a strange issue with an iPad application and our Brother Printer (QL-710W). The printer was not receiving print requests from the app. I turned off Drop Broadcast and Unknown Multicast temporarily to see if there were any packets being dropped, and found:
01:17:32.891198 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0 [5q] [5n] ANY (QU)? BRN008092DB3B7D.local. ANY (QU)? Brother QL-710W._pdl-datastream._tcp.local. ANY (QU)? Brother QL-710W._printer._tcp.local. ANY (QU)? Brother QL-710W._ipp._tcp.local. ANY (QU)?
01:17:33.149539 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0 [5q] [5n] ANY (QM)? BRN008092DB3B7D.local. ANY (QM)? Brother QL-710W._pdl-datastream._tcp.local. ANY (QM)? Brother QL-710W._printer._tcp.local. ANY (QM)? Brother QL-710W._ipp._tcp.local. ANY (QM)?
01:17:33.401330 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0 [5q] [5n] ANY (QM)? BRN008092DB3B7D.local. ANY (QM)? Brother QL-710W._pdl-datastream._tcp.local. ANY (QM)? Brother QL-710W._printer._tcp.local. ANY (QM)? Brother QL-710W._ipp._tcp.local. ANY (QM)?
01:17:33.661375 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 11/0/0 (Cache flush) A 10.14.100.10, (Cache flush) PTR BRN008092DB3B7D.local., (Cache flush) SRV BRN008092DB3B7D.local.:9100 0 0, (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/o
01:17:33.665537 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 8/0/0 (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/octet-stream,image/urf" "rp=ipp/print" "note=" "ty=Brother QL-710W" "product=(Brother QL-710W)" "adminurl=http://BRN008092DB3
01:17:33.697456 IP 10.14.100.10.138 > 255.255.255.255.138: NBT UDP PACKET(138)
01:17:33.698949 IP 10.14.100.10.137 > 255.255.255.255.137: NBT UDP PACKET(137): REGISTRATION; REQUEST; BROADCAST
01:17:33.906882 IP 10.14.100.10.137 > 255.255.255.255.137: NBT UDP PACKET(137): REGISTRATION; REQUEST; BROADCAST
01:17:34.160992 IP 10.14.100.10.137 > 255.255.255.255.137: NBT UDP PACKET(137): REGISTRATION; REQUEST; BROADCAST
01:17:34.683404 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 11/0/0 (Cache flush) A 10.14.100.10, (Cache flush) PTR BRN008092DB3B7D.local., (Cache flush) SRV BRN008092DB3B7D.local.:9100 0 0, (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/o
01:17:34.684101 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 8/0/0 (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/octet-stream,image/urf" "rp=ipp/print" "note=" "ty=Brother QL-710W" "product=(Brother QL-710W)" "adminurl=http://BRN008092DB3
01:17:36.724482 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 11/0/0 (Cache flush) A 10.14.100.10, (Cache flush) PTR BRN008092DB3B7D.local., (Cache flush) SRV BRN008092DB3B7D.local.:9100 0 0, (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/o
01:17:36.724912 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 8/0/0 (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/octet-stream,image/urf" "rp=ipp/print" "note=" "ty=Brother QL-710W" "product=(Brother QL-710W)" "adminurl=http://BRN008092DB3
01:17:39.568874 IP 10.14.100.10 > 224.0.0.252: igmp v2 report 224.0.0.252
01:17:40.803394 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 11/0/0 (Cache flush) A 10.14.100.10, (Cache flush) PTR BRN008092DB3B7D.local., (Cache flush) SRV BRN008092DB3B7D.local.:9100 0 0, (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/o
01:17:40.805711 IP 10.14.100.10.5353 > 224.0.0.251.5353: 0*- [0q] 8/0/0 (Cache flush) TXT "txtvers=1" "qtotal=1" "pdl=application/octet-stream,image/urf" "rp=ipp/print" "note=" "ty=Brother QL-710W" "product=(Brother QL-710W)" "adminurl=http://BRN008092DB3
01:17:42.223673 IP 10.14.100.10 > 224.0.0.251: igmp v2 report 224.0.0.251
Where 10.14.100.10 is the printer. It appears that it is trying to using IGMPv2, and various ._tcp.local. strings which may not be defined in our AirGroup setup. I am looking for some help in whitelisting the above multicast packets to ensure that we can re-enable Drop Broadcast and Unknown Multicast.
It looks as if AirPlay has some of these included, ie. _printer._tcp and _ipp._tcp. Do I need to specifically call out the pre-pended Brother Printer information to let it pass, or?
