BSSID information in AOS8.5 GUI
  • 1.  BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 01:23 PM
    Hello all,
    is there a way to view the BSSID information for an AP from the AOS8.5 GUI? we need this information for a voice product and need an easy way to gather it. The person in charge is not comfortable with going into CLI to get the info.
    thank you
  • 2.  RE: BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 01:28 PM
    Navigate to Dashboard > Overview and click on the Radio icon.
  • 3.  RE: BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 01:38 PM
    can you send me a screen shot of what you see? i cant find the BSSID info from where you are saying to go.
    thank you for the quick reply
    John
  • 4.  RE: BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 01:48 PM
    Please refer the AOS 8.5 user-guide (Page 398)
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=34189
    They give the information for each radio(This can be filtered further for the AP that the device connects to. The Radio is the fourth icon). This is more or less equivalent to the cli command "show ap bss-table"
  • 5.  RE: BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 02:18 PM
    i went through the page and i dont see where the BSSID information would be displayed.
  • 6.  RE: BSSID information in AOS8.5 GUI
    Posted Oct 02, 2019 02:28 PM
    How many SSIDs are being broadcast and on which radios?
    The BSSID is dynamically generated based on the mac-address of the AP.
    This post may shed some light on it.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-is-the-BSSID-derived-from-the-Access-Point-ethernet-MAC/ta-p/176290
    on another note,
    If you have the mac address of the AP then this link can be used to calculate the BSSIDs for Aruba APs.
    https://koopen.net/aruba_bssid.php
