BW Contracts with Captive Portal
  • 1.  BW Contracts with Captive Portal
    Posted Aug 17, 2018 11:23 AM
    Hello!
    I have a Aruba Mobility Controller 3400 with version: 6.4.4.9
    I have multiples SSID
    But one of these SSID is for Public connection the reason any one in the office like a internet connection use this SSID, this have a Captive Portal with only Agreement display without user and password to access, when trying to control the Bandwidth this don't work, but when remove the Captive Portal work fine de BW Contracts.
    I tested with Per User, Per Role and Per AP group.
    Thanks for any help!
  • 2.  RE: BW Contracts with Captive Portal
    Posted Aug 17, 2018 11:25 AM
    You need to put the bandwidth contract on the user role the user gets AFTER the user clicks on the Acknowledgement.  Do not put it on the logon--xxx role.
  • 3.  RE: BW Contracts with Captive Portal
    Posted Aug 17, 2018 11:45 AM
    Sorry for my ignorance of this, but when you say put in the User Roles you say the firewall policy where I created for that SSID, where have Firewall Policyes tab and Bandwidth Contracts Tab?
  • 4.  RE: BW Contracts with Captive Portal
    Posted Aug 17, 2018 11:48 AM
    This I have
  • 5.  RE: BW Contracts with Captive Portal
    Posted Aug 17, 2018 11:55 AM
    No.
    Edit the user role.  If you scroll down there is a place to add an upstream and/or downstream bandwidth contract.
  • 6.  RE: BW Contracts with Captive Portal
    Posted Aug 17, 2018 02:05 PM
    Sorry but I don locate that area when enter to the User Roles, when select the User Role and click edit display the page in the jpg previously
  • 7.  RE: BW Contracts with Captive Portal
  • 8.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 08:45 AM
    Thas exactly what I have in the Bandwidth Contracts tabs have a
    Upstream and Downstream settings,
    but what you mean whit this:
    "user gets AFTER the user clicks on the Acknowledgement.  Do not put it on the logon--xxx role."
    Image 213.jpgattached my settings
  • 9.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 09:54 AM
    Which user role are you applying the bandwidth contract to?
  • 10.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 10:08 AM
    This Bandwidth Contracts applyed only to this SSID
  • 11.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 10:11 AM
    Bandwidth contracts can only be applied to a role.  What role are they applied to?  That is crucial.
  • 12.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 10:19 AM
  • 13.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 11:13 AM
    That is the AAA profile, not the role.  What role do your users get after they click on "accept"?  That is the role that needs the bandwidth contracts.
  • 14.  RE: BW Contracts with Captive Portal
    Posted Aug 20, 2018 03:52 PM
  • 15.  RE: BW Contracts with Captive Portal
    Posted Aug 21, 2018 12:53 AM
    You need to assign bandwidth contract to the post authentication role, i.e. the role guest user gets after they are successfully authenticated or click "I accept the terms". Assigning BW contract to initial role will not help you as it will only will applied for the period user connects to the network and authenticates.
  • 16.  RE: BW Contracts with Captive Portal
    Posted Aug 22, 2018 11:23 AM
    Hello Sorry for the delay.
    I dont not have much experience with this kind of Controllers sorry for that, that is the reason for a lot of question for the same topic.
    but looking the controller configuration you told me change the authentication role and assign in there, just only saw that page where assig different kind on roles and the other page is the captive portal L3 authentication settings, is one of these pages where need to assig that role?
    Thanks!
