BYOD for Wired
  • 1.  BYOD for Wired
    Posted Mar 15, 2019 08:18 AM
    Hello ,
    We have a requirement for Wired LAN to provide access to BYOD devices .
    We dont have a standard vlan structure . and all the users /non standard devices fall in single vlan .
    So for BYOD , how to we restrict them ? We dont want to create a new VLAN for BYOD on swithces . IS there a way to redirect them to captive portal ( but without creating any vlan on the switch ) ?
    If yes , do we need captive portal config on switch ( HPE and Cisco) ?
  • 2.  RE: BYOD for Wired
    Posted Mar 15, 2019 08:42 AM
    Covered completely in the ClearPass Solution Guide for Wired Policy Enforcement.
  • 3.  RE: BYOD for Wired
    Posted Mar 15, 2019 01:47 PM
    Hi Tim, the wired guide says vlan is needed. Here my requirement is not to create vlan. Are you referring to onboard .? Can onboard be considered a solution?
  • 4.  RE: BYOD for Wired
    Posted Mar 15, 2019 01:50 PM
    You need *a* VLAN, it doesn’t have to be dedicated.
  • 5.  RE: BYOD for Wired
    Posted Mar 16, 2019 05:36 PM
    Hi Tim. Thanks .
    If we go for onboard for BYOD for wired , in that case how the wired user will be redirected for onboard portal . The BYOD user is a domain user .
    for wireless , we can create an SSID .but for Wired user how to redirect him for onboard portal
  • 6.  RE: BYOD for Wired
    Posted Mar 16, 2019 07:11 PM
    The role has redirection enabled as shown in the ClearPass Solution Guide for Wired Policy Enforcement.
