I am looking at implementing a BYOD solution for our Sixth Form. I have installed 4 Aerohive AP230s and will use Hive Manager Cloud Management to manage the wireless network side of the solution.
I have the following resources:
1 HP Switch 5406zl (J8697A) (Core)
1 HP 2530-48G-PoEP Switch (J9772A) (Edge - Sixth Form)
4 Aerohive AP230 Access Points
1 Aerohive Hive Manager
1 Microsoft Network Policy Server (RADIUS)
1 Smoothwall UPS S8 Appliance
The two switches are linked by a 1GB fibre connection.
I have created 2 VLANs: VLAN 10 and VLAN 20
VLAN 10 is named CORP_VLAN for Teachers and Staff access
VLAN 20 is named BYOD _VLAN for BYOD traffic internet access only
I have a RADIUS Server setup to use 802.1x Windows Authentication for both VLANs
On the core switch B3 connects to port 49 of the Edge switch and this is the fibre uplink connection.
The configuration of the 2 switches is as follows:
Core Switch: VLAN 1 Default_VLAN (Primary)
IP Address: 10.1.0.23
SM: 255.255.0.0
GW: 10.1.0.19
Ports Tagged: None
Ports Untagged: A1-A9,A11-A24,B1-B24,C1-C24
Core Swtich: VLAN 10 CORP_VLAN
IP Address: 10.6.0.10
SM: 255.255.0.0
GW: 10.1.0.19
Ports Tagged: B3
Ports Untagged: None
Core Switch VLAN 20 BYOD_VLAN
IP Address: 10.5.0.10
SM: 255.255.0.0
GW: 10.1.0.19
Ports Tagged: B3
Sixth Form Switch VLAN 1 Default_VLAN (Primary)
IP Address: 10.1.0.197
SM: 255.255.0.0
GW: 10.1.0.19
Ports Tagged: None
Ports Untagged: 1-24 29-52
Sixth Form Switch VLAN 10 CORP_VLAN
SM: 255.255.0.0
GW: No Gateway
Ports Tagged: 49
Ports Untagged: 25-28
Sixth Form Switch VLAN 20 BYOD_VLAN
SM: 255.255.0.0
GW: No Gateway
Ports Tagged: 49
DHCP Config:
Scope 10.1.0.0 (Default Scope | Default_VLAN)
Address Pool: 10.1...0.0 - 10.1.20.254
Router: 10.1.0.23 (Core Switch)
DNS Servers: 10.1.0.125, 10.1.0.126
Domain Name: acaciahighschool.local
Scope 10.5.0.0 (BYOD_VLAN)
Address Pool: 10.5.0.50 - 10.5.20.254
Router: 10.5.0.10
Scope 10.6.0.0 (CORP_VLAN)
Address Pool: 10.6.0.50 - 10.6.20.254
Router: 10.6.0.10
DNS Servers: 10.1.0.125, 10.1.0.125
Hi
The APs are all recieving IP addresses from VLANs 10 and 20, but when probing for VLANs from the AP230s they cannot find any VLAN apart from the Default_VLANs
My question is does the switching and routing look consistent and correct in combination with the DHCP scopes that are setup for the associated VLANs.
I would really appreciate some expert guidance on this
