Bypass Apple Captive Network Assistant and safari
  • 1.  Bypass Apple Captive Network Assistant and safari
    Posted Jun 04, 2014 11:26 AM
    Hello
    I dont know if anyone encounter this issue
    There is a client whcih has a mac and he was trying to authenticate through the captive portal
    I got this bypass feature on
    The captive portal works well on Google Chrome, but if the client tries safari it doenst work even if the by pass feature is on.
    Cheers
    Carlos
  • 2.  RE: Bypass Apple Captive Network Assistant and safari
    Posted Jun 04, 2014 12:11 PM
    You could have a different issue:  On the mac, go to Keychain> Preferences> Certificates.  Turn off OCSP and try again.
    If that works, search the forum for OCSP and Captive Portal and you will find the solution.
  • 3.  RE: Bypass Apple Captive Network Assistant and safari
    Posted Jun 05, 2014 09:22 PM
    Thanks for the suggestion Collin
    This was the fix
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/OCSP-captive-portal-issues-apple-laptops-amp-firefox/td-p/82456
    Victor Fabian Answer
    Cheers
    Carlos
