bypass enable mode password for user group
  • 1.  bypass enable mode password for user group
    Posted Apr 28, 2014 06:45 AM
    hi
    can we bypass enable mode authentication on controller for particular set of users or a single user..
    -Harshad
  • 2.  RE: bypass enable mode password for user group
    Posted Apr 28, 2014 07:33 AM
    Bypass enable is a global command.
  • 3.  RE: bypass enable mode password for user group
    Posted Apr 28, 2014 08:00 AM
    If you use an external RADIUS server for the users, you can return the Aruba VSA:  Aruba-Priv-Admin-User.   Just return any integer; I usually just use 1.  This will put the user in enable mode by default without having to bypass enable globally.
  • 4.  RE: bypass enable mode password for user group
    Posted May 05, 2014 08:37 AM
    for this attribute to work do I need to put any server derived rule..
    also can we do it for user created in controller internal database??
  • 5.  RE: bypass enable mode password for user group
    Posted May 05, 2014 09:04 AM
    No, you should not have to define it in the server derived rules.
    No, the VSA needs to be returned from RADIUS; there is no equivalent option for an internal user, VSA or otherwise.
