Hello eveyrone,
I'm working on HP iMC for about two months. My first job was to integrate the auto config backup of Gigamon devices, which wasn't initially planned in HP iMC. After few weeks, the job is done !
Now, we're experiencing an issue on Cisco Nexus 7K :
By default, HP iMC backup their configuration file easily. But ! Our Nexus 7K are configured with 2 VDCs. We'd like to backup a file in iMC wich contains the configuration of each one of device VDCs.
A solution that I've found is to make/modify TCL scripts and xml files of NexusIOSGeneric adapter folder, and add the appropriate option "vdc-all" to the backup command sent by script. Then it's necessary to move them into CiscoNX7K adapter folder, and remove the "<uses-adapter>" balise in its adapter.xml, which points out to NexusIOSGeneric adapter folder.
But, when SNMP Write is correctly configured, iMC is forcing a backup throught it instead of using my TCL scripts... The only way I've found is to remove the Write Community Field of the device in iMC, but I'd like to know if there's another way to force the use of scripts before SNMP instead of this tricky one way...
Thanks for your attention, hope someone will help me figure it out !
#Nexus7K#scripts#cisco#backup#tftp#snmp#imc
