Thanks to everyone.
(@JorchRock67: I am seeking a USB - RJ45 serial cable.)
According to the link Evan provided a cable with chipsets FT231X / PL3202 should work.
There is also mention that USB-A should be used.
My observations:
Raritan has autodetection.
When connecting example 2530 console to Raritan using RJ45 - RJ45, Raritan autodetects its role as DCE.
I have now successfully connected 6100 USB-A / AUX to Raritan / RJ45 using combination:
"Cisco Serial Cable RJ45-DB9" + "DB-9 USB 2.0 to Serial 9-Pin RS-232 Converter Cable"
Converter cable has FTDI chipset (not sure of exact chip version).
https://ftdichip.com/products/us232r-10-bulk/Raritan autodetects the port role as DTE and console access works just fine.
Example this did not work of the converters I tested:
https://www.aten.com/eu/en/products/usb-&-thunderbolt/usb-converters/uc232a/I am primary looking for part/order number for
"one-cable" solution that can be applied between Console server (Raritan) and AOS-CX (models 6000 - 6300).
Example this should have the suggested FT231X-chip:
https://www.amazon.com/Tekit-Cisco-Router-Console-Cable/dp/B07CV9GJM8Has someone maybe verified if this cable works on this use-case?
(I assume that there are 6000-6300 series used in such a critical environments where an emergency console access is required... and hoping that someone has already figured out a 100% working cable :-) )
Roy Lillqvist | ACSX #1421 | CCIE(RS) #38597
Original Message:
Sent: Feb 19, 2022 03:01 AM
Subject: Cable for AOS-CX switch console and serial console server
Depend of which ports your Console server have :
Console Server=>Switch:
RJ45/rs232 serial adapter => rs232/usb-A (like a cisco switch on your computer but inverted)
or
usb-C => usb-C
or
usb-A => usb-C
But it sucks the 6000CX's does not have RJ45 serial ports likes the 8000CX.. usb is not a reliable connexion for datacenter.
Laurent TYGREAT
Original Message:
Sent: Feb 18, 2022 08:14 AM
I'm having a hard time when trying to identify which type of a cable is required to connect AOS-CX switch (6000-6300) and serial console server / RJ45 (Raritan Dominion SX II / DSX2-32). Tested some USB-C to RJ45 and USB-A to RJ-45 but with no success.
If I have understood right, the console server should be connected to the switch USB-A / AUX and not the USB-C / console port?
Maybe someone knows and could share information of exact cable type that is required and verified to work (type/model, manufacturer, part number etc.)?
Roy Lillqvist | ACSX #1421 | CCIE #38597
