Education - Australia / New Zealand
last person joined: 22 days ago
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
Cable Testing using Aruba Central
  • 1.  Cable Testing using Aruba Central
    Posted Nov 25, 2019 06:43 AM
    We can run cli command to a switch to detect cable faults. If the switch is cloud managed in Aruba Central we can use the GUI to test the cable.
    Test Details:
    • Aruba Central - AUTO-ATH-2.4.9-687-P
    • 2930F switch
    • AP-515
    My AP is connected to port 4 of 2930F with 4 meters cable. I will check if I have cable faults using Aruba Central.
    1. Under Maintenance > Tools > Device Check . Run "Cable Test" to a selected switch.
    2. Refresh the page to see the test results.
    3. Or you can laso check the cable test result by issuing show cable-diagnostics. Maintenance > Tools > Adanced.
    Based on the test result my cable is good and also it confirmed that it is 4 meters long. Very useful command to test layer 1.
  • 2.  RE: Cable Testing using Aruba Central
    Posted Nov 25, 2019 05:46 PM
    will this work for all switches/AP's supported by central?
  • 3.  RE: Cable Testing using Aruba Central
    Posted Nov 25, 2019 07:09 PM
    2930F, 2930M, 3810M, 5400R v3 modules supported it.
