Hi!
We bought Aruba 2540 and 2930 and I want to monitor and graph them with Nagios and Cacti. Is there any template available for that?
We do not have Cacti templates or Nagios Plugin's for our ArubaOS-Switch product lines. The solution we offer is Airwave which is a cost effective comprehensive SNMP configruation and monitoring platform.
Thanks.
Where can I get the enviroment variable MIB for these switches?
2930M MIBS - https://h10145.www1.hpe.com/Downloads/DownloadSoftware.aspx?SoftwareReleaseUId=22402&ProductNumber=JL321A&lang=en&cc=au&prodSeriesId=5159863&SaidNumber=
2930F MIBS - https://h10145.www1.hpe.com/Downloads/DownloadSoftware.aspx?SoftwareReleaseUId=24068&ProductNumber=JL559A&lang=en&cc=au&prodSeriesId=5159863&SaidNumber=
2540 MIBS
https://h10145.www1.hpe.com/Downloads/DownloadSoftware.aspx?SoftwareReleaseUId=24068&ProductNumber=JL356A&lang=en&cc=au&prodSeriesId=5159863&SaidNumber=
Thanks and sorry for late response.
I have seen the MIB but its not easy to filter it out. Perhaps it most easy to get some common OID's for CPU, Memory and hardware for these specific models.
Switch use "Standard" MIB for this...
I have downloaded the MIB for 2540 but its long list and cannot figure out which one I can use to find the Mib for Cpu, Memory.
Hello Guys!
Anyone can share Oid for 25xx series switches?
