Calculate radius session timeout based on MAC-Auth Expiry
This thread has been viewed 33 times
  • 1.  Calculate radius session timeout based on MAC-Auth Expiry
    Posted Sep 22, 2021 06:48 AM
    My customer has shared devices and they want to track users connecting to these devices.  Devices are tablets and they want users to authenticate by Captive Portal against AD and re-authenticate every 2 hours. I was able to create required filter in [Time Source] and users get  MAC-Auth Expiry  set correctly, but I am not able to set session timeout to match the same time. I want users to be disconnected at MAC-Auth Expiry time and authenticate by captive portal again.
    is there a way to set radius Session-Timeout to be (MAC-Auth Expiry - Current Time) in seconds?
    Ahmad Enaya
  • 2.  RE: Calculate radius session timeout based on MAC-Auth Expiry
    Posted Sep 22, 2021 04:09 PM
    Create a new filter in Endpoint Repository using the below query:
    select (extract(epoch from(to_timestamp(attributes->>'MAC-Auth Expiry','YYYY-MM-DD HH24:MI:SS'))) - extract(epoch from(now())))::int as Remaining from tips_endpoints where mac_address ='%{Connection:Client-Mac-Address-NoDelim}';
    Then create an enforcement profile for session timeout
    Enable authorization under the service and add Endpoint Repository
    And map to the Service which will return the timeout in seconds
    SANDEEP YADAV
    Global Escalation Center, ACCP
  • 3.  RE: Calculate radius session timeout based on MAC-Auth Expiry
    Posted Sep 28, 2021 10:35 AM
    Amazing! This worked. Thank you Sandeep
    Ahmad Enaya
