Campus WLAN wizard only creates "aruba-ap"
  • 1.  Campus WLAN wizard only creates "aruba-ap"
    Posted Oct 03, 2016 03:49 AM
    Mobility controller 7200, some 30 AP-215. Software version 6.4.4.9
    Whatever SSID (PSK) I try to create with the Campus WLAN-wizard only creates an SSID "aruba-ap". If I try to create another SSID i get an error like "Error: Duplicate ESSID "aruba-ap"".
    If I remove the erroneus "aruba-ap" I'm able to create a new SSID, but this one too, is named "aruba-ap".
    Has anyone else encountered this problem?
  • 2.  RE: Campus WLAN wizard only creates "aruba-ap"
    Posted Oct 03, 2016 04:01 AM
    Also, I have found that using the same wizard to remove a WLAN works weird. If I highlight a WLAN, and click Delete, the WLAN won't be deleted until I step through the wizard for any other WLAN available.
  • 3.  RE: Campus WLAN wizard only creates "aruba-ap"
    Posted Oct 03, 2016 04:22 AM
    I upgraded to 6.5.0.1 and the problem is still there.
  • 4.  RE: Campus WLAN wizard only creates "aruba-ap"
    Posted Oct 03, 2016 04:33 AM
    Found a workaround so I can continue with other stuff. Went to Configuration -> AP Group -> Edit "group"
    Clicked Wireless LAN -> Virtual AP -> "TheSSID-vap_prof" -> SSID and set the SSID from "aruba-ap" to the desired value.
