last person joined: 7 hours ago
can 2 RAP109s in instant mode do seemless roaming?
  • 1.  can 2 RAP109s in instant mode do seemless roaming?
    Posted Jul 01, 2014 06:37 AM
    Just wondering and is there any kind of roaming assist features?
    Does it do this automatically as part of the auto-clustering?
  • 2.  RE: can 2 RAP109s in instant mode do seemless roaming?
    Posted Jul 01, 2014 07:32 AM
    There is either between clusters and within a cluster and in version 4.1 they more roaming capabilities
    What type of authentication are you using ?
  • 3.  RE: can 2 RAP109s in instant mode do seemless roaming?
    Posted Jul 01, 2014 07:41 AM
    WPA2 keys
  • 4.  RE: can 2 RAP109s in instant mode do seemless roaming?
  • 5.  RE: can 2 RAP109s in instant mode do seemless roaming?
    Posted Jul 01, 2014 08:27 AM
    Thanks for the link.
