last person joined: 11 hours ago
Can a 635 access point join in with a group of 205's?
  • 1.  Can a 635 access point join in with a group of 205's?
    Posted 27 days ago
    I have 30 access points that are IAP-205's.  They all work great.  It is possible to start adding newer AP's such as a 635 into the same setup?  If so what are the requirements?
  • 2.  RE: Can a 635 access point join in with a group of 205's?
    Posted 27 days ago
    Both are supported only in 8.10.
    Carson Hulcher, ACEX#110
  • 3.  RE: Can a 635 access point join in with a group of 205's?
    Posted 27 days ago
    Is it the case that the 205's cannot be upgraded to 8.10?
  • 4.  RE: Can a 635 access point join in with a group of 205's?
    Posted 27 days ago
    Sorry, was looking at the wrong list.  AP-200 is parked in 6.5 for IAP, AP-635 is going to require 8.10 at this point.  So no, you can't add anything current to the old Instant cluster.
  • 5.  RE: Can a 635 access point join in with a group of 205's?
    Posted 27 days ago
    That's correct.
    • IAP-103, IAP-204, IAP-205, and IAP-205H IAPs are no longer supported from Aruba Instant 8.3.0.0 onwards.
    For the 635 we need 8.9 and above.
    HPE Aruba Networking AP-635:
    –HPE Aruba Networking OS and HPE Aruba
    Networking InstantOS 8.9.0.0, HPE Aruba
    Networking OS 10.4.0.0
    https://www.arubanetworks.com/assets/ds/DS_AP630Series.pdf
    Sajin
