last person joined: 5 hours ago
Can a configuration file be pushed to IAP and how%3F
  • 1.  Can a configuration file be pushed to IAP and how%3F
    Posted Jun 26, 2015 05:58 PM
    I have IAP connected to a L2 switch. The network has a DHCP server. There is no access to Activate server, no Aruba Central, no wireless lan controller or Airwave. Can a pre-defined configuration  be pushed to the IAP and applied from a third party management platform.
  • 2.  RE: Can a configuration file be pushed to IAP and how%3F
    Posted Jun 26, 2015 06:02 PM
    No this is not possible.
    The only way you could do something like this is to have a script the SSHs
    to the VC and copies a configuration or enters it in.
