Can a IAP205H be used with an IAP225 Virtual Controller ?
  • 1.  Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted May 29, 2015 02:07 PM
    Aruba newbie...
    I currently have several IAP225s managed by a single Virtual Controller. Can I use this same V.C. to also manage IAP205Hs?
  • 2.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted May 29, 2015 02:17 PM
    Yes , just need to make sure it has the same version of code as you current IAP225 cluster
  • 3.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted May 29, 2015 02:38 PM
    When you mention "same version of code" do you mean same firmware version?
  • 4.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted May 29, 2015 03:03 PM
    Yes , make sure it is before you join it to the cluster
  • 5.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted Jun 16, 2015 09:02 AM
    Got access to the firmware section and downloaded the latest version for the 205 but it gave me an incompatible message when I tried to upgrade the AP. Did a quick search and it appears that the 205 and 205H are different models. Is there a firmware version 6.4.2.6-4.1.1.7 available for the 205H?
  • 6.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted Jun 16, 2015 10:54 AM
    There is not yet an IAP version of the 205H.
  • 7.  RE: Can a IAP205H be used with an IAP225 Virtual Controller ?
    Posted Jun 10, 2015 11:51 AM
    Tried getting to the software download section to get the latest so that both my iAP225 cluster and new iAP205H have the same firmware but I don't have that option on my Aruba web page.
    I'm suppose to see a Dowlonad Software tab under which these downloads are located but it's no longer there.
    Has it been moved?
