Network Management
Can Airwave monitor Lenovo System x3850 X6 using SNMP?
  • 1.  Can Airwave monitor Lenovo System x3850 X6 using SNMP?
    Posted Jan 14, 2016 03:00 AM
  • 2.  RE: Can Airwave monitor Lenovo System x3850 X6 using SNMP?
    Posted Jan 14, 2016 07:53 AM
    Airwave is able to monitor "universal snmp devices" you will get basic information from it. it will be limited to Up/Down only.
    if you do a search on this community for it you will what mibs specifically are being looked at. I don't have it at my fingertips right now
  • 3.  RE: Can Airwave monitor Lenovo System x3850 X6 using SNMP?
    Posted Jan 14, 2016 03:50 PM
    Hey @Minime,
    As mentioned, Airwave can help you out with basic SNMP stats, but if you're looking for more, you do have IMC in the Aruba portfolio now as well which will let you get quite a bit more.
    IMC will give you all the standard SNMP ( v1/v2c/v3 support of course! ) as well as allow you to add custom SNMP monitors for any OIDs that the IBM server supports.
    Don't mean to highjack the question, but just offering up another soltution from the same great company.
    @netmanchris
