Can an IAP-275 use 802.3at? Radios not coming up
  • 1.  Can an IAP-275 use 802.3at? Radios not coming up
    Posted Sep 16, 2014 09:47 AM
    Can an IAP-275 be powerd by 802.3at or does it need a special injector? The radios will not come up on this one. Here is the output from the CLI "Shutting down radios due to insufficient POE voltage [power profile 2]"
    Looking at the switch port the IPA is drawing 15.4 watts
  • 2.  RE: Can an IAP-275 use 802.3at? Radios not coming up
    Posted Sep 16, 2014 09:52 AM
    Can you enable LLDP on your switch port and see if that helps?
  • 3.  RE: Can an IAP-275 use 802.3at? Radios not coming up
    Posted Sep 16, 2014 10:12 AM
    The AP-275 does need 802.3at.   No special adapter is required.
    What switch are you using?
  • 4.  RE: Can an IAP-275 use 802.3at? Radios not coming up
    Posted Sep 16, 2014 10:47 AM
    Enabling LLDP on the 2960-S-24PS did the trick. Thank you very much for the quick responses.
  • 5.  RE: Can an IAP-275 use 802.3at? Radios not coming up
    Posted Sep 16, 2014 10:46 AM
    That did it.... thanks. Hmm, bet you can't tell I come from a Cisco/CDP world...
