Can an Instant RAP-3 mesh?
  • 1.  Can an Instant RAP-3 mesh?
    Posted Jun 26, 2013 01:53 PM
    All,
    I had a quick question. Can a RAP-3 join an instant domain via mesh? Or, is it a requirement that you need multiple radios, for backhaul purposes, to pull this off?
    I've seen the mesh feature workon an AP105 and an AP135, but I've never tried it on the RAPs.
    Thanks!
    -Mike
  • 2.  RE: Can an Instant RAP-3 mesh?
    Posted Jun 26, 2013 02:02 PM
    Is not possible with a RAP3 since is not dual radio like IAP135 or 105
    The mesh is built using the 5 ghz band
