Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
  • 1.  Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 20, 2014 12:45 PM
    The sizing guide only lists the hardware requirements.
  • 2.  RE: Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 22, 2014 12:07 PM
    doesnt it say it is 20% more for virtual? and dedicated resources.
  • 3.  RE: Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 23, 2014 08:34 AM
    The +20% appears to apply to I/O.
  • 4.  RE: Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 23, 2014 02:00 PM
    i read this in the 8.0 hardware sizing guide
    Virtualization
    AirWave can run in a virtualized environment. To ensure scalability, dedicate the processing and memory. You must
    also ensure that the disk subsystem can maintain the IOPs throughput as detailed below.
    Most virtualized environments use a shared disk subsystem assuming that each application will have bursts of I/O
    without a sustained high I/O throughput. AirWave requires a continuous sustained high data I/O rate.
    Aruba recommends a 20% increase buffer for virtual environments. Ensure you allocate enough extra disk space for the
    OS and swap when partitioning the virtual disk.
     which i read as in general take 20% extra for a virtualized environment and make sure it is dedicated for this.
  • 5.  RE: Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 23, 2014 02:04 PM
    I read the same thing...just looking for some confirmation.
  • 6.  RE: Can anyone tell me the VM requirements for AMP 8.x --1500 devices?
    Posted Jun 23, 2014 06:22 PM
    Yes you should add 20% to the recommended hardware specs (CPU, memory, disk IO, etc).
