Can APs/VAPs take different config in failover?
  • 1.  Can APs/VAPs take different config in failover?
    Posted Dec 17, 2012 04:25 AM
    Just wondering if it is possible when APs fall over to their bk-lms-ip that they take slightly different configuration?
    I'm thinking that when the local controller is up, the VAPs are tunnelled and when they failover to a remote controller the VAPs are then bridged?
    I don't think this is possible, but would be great if it was.
  • 2.  RE: Can APs/VAPs take different config in failover?
    Posted Dec 17, 2012 06:09 AM
    you have to have the same AP Group Name in both controllers but with different configuration in each for the mode of operation.
    I belive this is the way to do it, if the AP lose the configuration from the first controller
  • 3.  RE: Can APs/VAPs take different config in failover?
    Posted Dec 17, 2012 06:12 AM
    Unfortunately that means two separate systems and we need to have cpsec enabled.
