Can Aruba Controller Support 802.3ad?
  • 1.  Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:18 PM
    I saw this post: Can Aruba Controller Support 802.3ad? which is a little dated but I'm not sure if it holds true because i couldn't follow the link referenced. I was looking into creating a link agg with a palo alto device and I was told that they don't support LACP just traditional 802.3ad. Does the 7240 controller support this?
    As always - thanks,
    Rosie
    #7240
  • 2.  RE: Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:21 PM
  • 3.  RE: Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:27 PM
    Thanks for the quick reply!
    Do you know if there would be a problem mixing the copper and sfp ports?
  • 4.  RE: Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:39 PM
    So just to confirm you want to create a static port channel not an LACP based port channel correct? If it is the former, you can also refer to this config snippet in the KB.
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-139
    There shouldn't be a problem mixing copper and SFP ports as long as the speeds are the same (e.g. 1G).
    Best regards,
    Madani
  • 5.  RE: Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:43 PM
    Yes, it's my understanding that we'd need to configure it manually/statically.
    Thanks for the config snippet!
  • 6.  RE: Can Aruba Controller Support 802.3ad?
    Posted May 06, 2014 12:38 PM
    This is the information from PA that I was going by:
    https://live.paloaltonetworks.com/docs/DOC-3594
    where a users posts:
    "PAN OS 5.0 support Link Aggregation on all models
    But, it’s just configured manual (same mode ON EtherChannel).
    LACP is a protocol, PAN is not support."
