Can Aruba controller support QR code authentication
  • 1.  Can Aruba controller support QR code authentication
    Posted Oct 19, 2017 02:46 AM
    Can Aruba controller support QR code authentication?
  • 2.  RE: Can Aruba controller support QR code authentication
    Posted Oct 19, 2017 02:58 AM
    Can you give us an example please?
  • 3.  RE: Can Aruba controller support QR code authentication
    Posted Oct 19, 2017 03:05 AM
    Which is before allow the user to access network, must be authenticate by using QR code either through captive portal, etc. Which mean the QR code itself is user ID
  • 4.  RE: Can Aruba controller support QR code authentication
    Posted Oct 20, 2017 10:34 PM
    as far as i know, it is not supported, at least with aruba controller and clearpass, but you may found a third party mecanism that can help you to do your authentication with the QR code
  • 5.  RE: Can Aruba controller support QR code authentication
    I believe you may require it to be redirected to a external captive portal with QR authenication features for it to work.
