Can Aruba support 2 wlans using two different radius servers
  • 1.  Can Aruba support 2 wlans using two different radius servers
    Posted Aug 18, 2015 07:43 PM
    Does Aruba support per SSID radius authentication? If so, please explain the configuration behind the following.
    ssid a authenticates against radius server a
    ssid b authenticates against radius server b
    Lastly, what are the default aaa timeouts and can they be adjusted?
  • 2.  RE: Can Aruba support 2 wlans using two different radius servers
    Posted Aug 18, 2015 07:46 PM
    1.  yes.  When you create a wireless network with the wizard, you are asked what radius server you want to point it to.
    2.  When you say default AAA timeouts, what do you mean?
  • 3.  RE: Can Aruba support 2 wlans using two different radius servers
    Posted Aug 18, 2015 08:05 PM
    What are the default timeouts for authentication? For instance, I have a high latency link that I want to authenticate over..
    Bill Dugas
  • 4.  RE: Can Aruba support 2 wlans using two different radius servers
    Posted Aug 18, 2015 08:10 PM
    The 802.1x timeout is typically 2 seconds.  Many 802.1x clients themselves give up after 100 miliseconds.
  • 5.  RE: Can Aruba support 2 wlans using two different radius servers
    MVP
    Posted Aug 19, 2015 06:01 AM
    See the attached .pdf to get a better understanding of how different profiles are combined to result in the network configuration.
    Since a network config is tied into a virtual-ap profile which can include different SSID and aaa profiles the short answer to your question is: Yes, Aruba supports per SSID authenticatio.
    disclaimer: That .pdf is from an antiquated version (3.0) but the logic hasn't realy changed since so still current to get a basic understanding. It certainly does NOT include all the possible profiles !
    Attachment(s)
    pdf
    3dot0-profiles-v2a.pdf   19 KB 1 version
