can clearpass join multiple domains in the same time?
This thread has been viewed 27 times
  • 1.  can clearpass join multiple domains in the same time?
    Posted Jun 17, 2015 03:36 AM
    I want to add two join clearpass to 2 diffrent domain at the same time is it possible
    example
    blue.com
    gteen.com
  • 2.  RE: can clearpass join multiple domains in the same time?
    Posted Jun 17, 2015 03:41 AM
    Yes
  • 3.  RE: can clearpass join multiple domains in the same time?
    Posted Jun 17, 2015 05:04 AM
    Yes.
  • 4.  RE: can clearpass join multiple domains in the same time?
    Posted Jun 17, 2015 04:36 PM
    I think our limit is 64 (sixty-four) unique domains that can be joined.
  • 5.  RE: can clearpass join multiple domains in the same time?
    Posted Jun 17, 2015 09:52 PM
    Hmm, I sent this response earlier, but I guess email response might not be working...
    ClearPass can join multiple domains and even auth against those domains in the same service! In fact you can auth against any (and multiple) compatible auth sources in the same service (AD, LDAP, Guest User DB, Local User DB, Postgres, MySQL, MS SQL, and Oracle 11g).
    What this means is that the same SSID could have user accounts it any of those places. Then, if necessary, you can differentiate access based on the auth source and/or other attributes we get from those auth sources.
