Can ClearPass send a RADIUS framed-mtu value to wireless client?
This thread has been viewed 55 times
  • 1.  Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 06, 2019 08:08 PM
    Can ClearPass send a RADIUS framed-mtu value to wireless clients at the beginning of the EAP-TLS session?
    In some integrations we see that firewalls drop fragmented UDP (RADIUS) and in ClearPass the Access Tracker tells us that the wireless client did not complete the EAP-TLS transaction. In this scenario I am seeing EAP-TLS Client Hello frames above 1600 Bytes from my Aruba IAP virtual controller. These large frames get fragmented by the infrastrcuture and dropped by a firewall policy. Consequently, ClearPass and the wireless client do not complete EAP-TLS.
    I know that Microsoft NPS can send a Framed-MTU as part of a Network Policy [https://community.arubanetworks.com/t5/Wireless-Access/Tutorial-EAP-TLS-Configuration-Guide/td-p/78592].
  • 2.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 06, 2019 09:36 PM
    Administration » Server Manager » Server Configuration > Service Parameters > RADIUS: EAP-TLS Fragment Size
  • 3.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 06, 2019 09:38 PM
    Hi Tim,
    Thank you for the quick response. The default EAP-TLS Fragment Size on ClearPass is 1024. My wireless clients still send EAP-TLS client hello messages in excess of 1600 Bytes.
  • 4.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 06, 2019 09:40 PM
    Please work with Aruba TAC.
  • 5.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 06, 2019 09:50 PM
    I took my query there before coming here. The ClearPass and Wireless Aruba TAC teams did not have a solution.
  • 6.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 07, 2019 12:08 AM
    Please ask for your case to be escalated.
  • 7.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 07, 2019 12:09 AM
    Thanks Tim.
  • 8.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted May 07, 2019 07:15 PM
    Hi Col,
    Experiencing same issue in our environment as well.  Did you make any progress with your escalation?
  • 9.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Oct 31, 2019 12:57 AM
    likewise i'd be keen to hear resolution as i'm having similar client issues.
    wondering if windows updates could be responsble for change in client behaviour.
  • 10.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Feb 27, 2020 02:51 PM
    Any Luck on this.  I have been fighting this for a year with no answers.
  • 11.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Jun 21, 2022 11:06 AM
    No updates in two years? Does anyone have any workaround on how to set the maximum fragment size for an EAP packet on the client?
  • 12.  RE: Can ClearPass send a RADIUS framed-mtu value to wireless client?
    Posted Jul 21, 2022 10:16 AM
    You are responding to a very old discussion. Please open a new discussion with a description of your issue, client, NADs in use, version numbers.
    This is not a common issue as far as I know, so please open a TAC case if you have this issue.
