can copy aurba controller 620 configuration file to 7005 ?
  • 1.  can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:07 AM
    we have controller 620 , now I want to copy the configuration to controller 7005, is it possible?
    Thanks in advance
  • 2.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:15 AM
    You can do that, but the 7005 will not have any connection to the outside world, because the interface commands will be reset.  You would need to have a console cable ready when the 7005 is booting up so that you can configure the interface ports correctly using the commandline.
  • 3.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:21 AM
    Thanks for your kind reply.  the controller configuration file is under  maintenance--.> copy files --> Flash File system , right?
  • 4.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:22 AM
    Hi Friend,
    While you are planning to migrate an old controller to a new model you have consider the following points,
    1. WLAN configurations
    2. L2 and L3 configurations
    3. Local database
    4. License
    As a good and successful practice,
    1. take the flash backup from the old controller, use the command " backup flash"
    this take care of first 3 requirements.
    2. boot the new controller and factory rest the controller, use the command " write erase all"
    3. After rebooting the controller, copy the backup file in to the flash
    note the file name must be "flashbackup.tar.gz"
    4. restore the flash backup, use the command " restore flash "
    5. Now configure the L2 and L3 interfaces accordingly ( mostly you have to work on mapping interface to the respective VLANs)
    6. transfer the license.
    7. reboot the controller.
    for any reason if the flash is not restored, please repeat the steps 1,3 and 4
    Hope got some more clarity,
    Please feel free for any further query on this.
  • 5.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:40 AM
    Thanks a lot. Tomorrow I will try , if have any problem, I may need your advice again. Have a nice day.
  • 6.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 07:41 AM
    Sorry, one more question: is 7005 more powerful and more stable than 620? what are the new features 7005 has? thanks
  • 7.  RE: can copy aurba controller 620 configuration file to 7005 ?
  • 8.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 08:50 AM
    Both are designed for branch office deployment , as you said 70XX controllers are equiped with high hardware config compared to 6XX
    1. Having More AP capacity (min 16 and Max 64 )
    2. Max user capacity ( 1024 to 4096)
    3. Active FW sessions ( 16000 to 65000 )
    4. More VLANs 4094
    5. Firewall throughput ( 1.2 GHz to 2 Ghz )
    6. All are 1 Gig ports
    7. SFP ports
    8. Supports 11ac
    9. 7005 can be powered up over POE
    and many more powerful features compared to 6XX controllers :)
    hope got required information,
    please feel free for any further query on this.
  • 9.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jan 27, 2015 09:35 AM
    owww, very good, aruba network online tech support is so good ah ... thanks a lot , aruba will  be giant soon because have you guys.
  • 10.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jul 02, 2015 04:13 PM
    I'm trying to preform the same migration, but when I try to copy the backup from the old controller off of a usb disk using the command "#copy usb: flashbackup.tar.gz flash: flashbackup.tar.gz" I recieve an error that says "Command is not supported in this platform"
  • 11.  RE: can copy aurba controller 620 configuration file to 7005 ?
    Posted Jul 08, 2015 10:33 AM
    I ended up getting this to work using an FTP server, but after rebooting the controller it got stuck in a reboot loop.
    After contacting Aruba support, it looks like the backup corrupted my flash partition. We are currently trying to get the controller to let us re-apply the OS image to the flash 0:0 partition, but after 3 hours we are still not having any luck.
    I'll keep you posted on the final resolution.
