Can I allow local auth. from the CLI?
  • 1.  Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 03:32 AM
    Hello!
    We have a problem: our customer unchecked checkbox "Allow local authentication" on Admin page of controller. Becouse we lost admin access to controller.
    Also our customer forgot "enable" password :smileymad: . But I have access to serial port of controller and (theoretically) "enable" password isn`t a problem for me.
    But... Can I enable "Allow local authentication" logon method from the CLI??? What should I do for this?
    P.s. I know one method - reset controller to factory defaults but it`s not right... Maybe.
    Best regards.
  • 2.  RE: Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 05:54 AM
    I'm not sure but I guess you can use the password/forgetme procedure from the console: http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Resetting-enable-password/td-p/15093
    If you are in with administrative privileges you can do pretty much everything.
    Did the customer uncheck the "Local Authentication Mode" option at Configuartion/Administration? If so I guess "no mgmt-user localauth-disable" will do the job.
  • 3.  RE: Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 07:24 AM
    Thank you! Problem has solved!
  • 4.  RE: Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 06:58 AM
    :smileyhappy:
    Good morning,
    Here you go:
    To restore the admin password on the controller, follow these steps:
    Log in from the console.
    Use "password" as the user name and use "forgetme!" as the password.
    Enable the mode password as "enable".
    In configuration mode, enter the ‘mgmt-user admin root’ command to reset the admin password.
    Re-login using the new admin password.
    In configuration mode, enter the ‘enable secret’ command to reset the enable mode password.
    For example:
    User: password
    Password: forgetme!
    (aruba) >enable
    Password: enable
    (aruba) #configure terminal
    Enter Configuration commands, one per line. End with CNTL/Z
    (aruba) (config) #mgmt-user admin root
    Password:
    Re-Type password:
    (aruba) (config) #exit
    (aruba) #exit
    (aruba) >exit
    User: admin
    Password:
    (aruba) >enable
    Password: enable
    (aruba) (config) #enable secret
    Password:
    Re-Type password:
    (aruba) (config) #write memory
    after you will do it - you will able to log into the controller with the new password/enable password and to enable the local auth.
    have a gr8 day.
    me
  • 5.  RE: Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 07:23 AM
    Thank you for answer.
    I'm tried it - I'm restored an admin account and "enable" password, but I did not have an admin access from web-interface.
    Solution have been described in post #2: it`s command "no mgmt-user localauth-disable"
    Thanks a lot! Problem has solved!
    P.s. I'm apologize for my bad english :)
  • 6.  RE: Can I allow local auth. from the CLI?
    Posted Mar 18, 2013 07:25 AM
    Glad to hear it! :smileywink:
