Can I build an Instant cluster by different AP models, if their classes are different?
  • 1.  Can I build an Instant cluster by different AP models, if their classes are different?
    Posted Oct 25, 2018 10:38 AM
    Hi Guys!
    For example, if I would like to build a cluster, which contains:
    (It's an extra mixed environment, just for example)
    IAP-103-RW
    IAP-207-RW
    IAP-315-RW
    AP-345-RW
    IAP-275-RW
    AP-365-RW
    Can I do it, or not? (Suppose that they are in the same L2 domain and runs the same fw version)
    Thanks!
  • 2.  RE: Can I build an Instant cluster by different AP models, if their classes are different?
    Posted Oct 25, 2018 11:20 AM
    As long as they all run the same firmware version, yes.
  • 3.  RE: Can I build an Instant cluster by different AP models, if their classes are different?
    Posted Nov 05, 2018 03:35 AM
    Thanks for your quick answer!
    If I built a mixed cluster, what about a software upgrade process?
  • 4.  RE: Can I build an Instant cluster by different AP models, if their classes are different?
    MVP EXPERT
    Posted Nov 05, 2018 03:48 AM
    Hey, take a look at the below this details your options to a mixed class IAP upgrade.
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Basic_conf_tasks/Firmware_Image_Server_in.htm
  • 5.  RE: Can I build an Instant cluster by different AP models, if their classes are different?
    Posted Nov 05, 2018 04:15 AM
    Thanks, every question is answered. :)
